s.in.ascii
Hi Moritz,
On Tue, Sep 19, 2000 at 11:41:32AM +0200, Moritz Lennert wrote:
> Hello,
> I managed to import my files, noticing two thnigs:
> - If I understand right, the category number is obligatory, so, even if
> there's only coordinates, and no categories defined, one has to add a #0 at
> the end of each line.
Actually this is not intended. You should be able to import
x1 y1 z1
x2 y2 z2
without #cat column. If not possible, this would be a bug.
I just have X, Y and I always get the "WARNING: error scanning
floating point attribute" when I try to import them on their own. But when I
add a third column with #0 it works alright.
> - In tcltkgrass, the s.in.ascii module seems to be bugged concerning the "fs"
> switch. In console mode I have to type "fs=;" (with quotes) for it to work ,
> tcltkgrass doesn't seem to add the quotes.
No, it doesn't. But just enter
into the fs field (comes out as fs=";" then).
This should work.
When I enter that I get 'Error: missing " '.
Moritz
