s.menu problem on RS6000
As we continue to have fun getting grass to run on the RS6000 in
our library, we ran into an unusual problem with the s.menu
command.
We have installed GRASS on an RS6000 model 340 with 128mb of ram
600 mb of swap space and the /tmp have about 130mb open. We are
running AIX 3.2
After reading in a site file and asking to run a site occurrence
report, the sites do not show up in the report as being in the
categories we know them to be.
The following is the report from a map created called layers,
which is jus an elevation map rescaled to 10 categories
here is the information after reading in the site
_______________________________________________________________
SITES MAIN MENU (current list: 82 sites, 82 in current region)
33.34514529(RES)
MAPSET: buildout 731850(E) 684750(W)
33.35694051(RES)
MASK: none
_________________________________________________________________
here is the report with a quad size of 8 cells:
                             SITE OCCURENCE REPORT
      page 1
                                Unknown Location
Mapset: buildout
Site List: ahist.sites (82 sites)
Analysis Region:
                    north: 4248550
   west: 684750 east: 731850
                    south: 4201500
Layer: layers rescale of elev.50
cells in analysis region: 1992332
sites in analysis region: 82
      degrees
                                cells % expected actual
chi of
Site Characteristics cover cover sites sites
square freedom
( 1) 49 thru 144 163041 8.2 0.0 0
( 2) 145 thru 241 801862 40.2 0.0 0
( 3) 242 thru 338 346848 17.4 0.0 0
( 4) 339 thru 434 286534 14.4 0.0 0
( 5) 435 thru 531 117825 5.9 0.0 0
( 6) 532 thru 627 102327 5.1 0.0 0
( 7) 628 thru 724 74673 3.7 0.0 0
( 8) 725 thru 820 67890 3.4 0.0 0
( 9) 821 thru 917 25167 1.3 0.0 0
( 10) 918 thru 1014 5796 0.3 0.0 0
( 11) 1015 thru 1110 369 0.0 0.0 0
      Totals 1992332 100.0 0.0 0
0.000 10
This same site list was run using grass4.0 on a sunsparcs 1
workstation without problem.
Why would there be no sites showing up in the different elevation
zones?
Thank you
Jim Klein
