>Does anyone know if there is an upper limit to the amount of sites, s.menu
>can convert to a rastfile? If I have a very large site file (139203 sites).
>s.menu seems to read the site file, but skips the SITES to CELL part, returning>to the main menu.....
>Smaller site files work okay.
>The alternative, s.to.rast does not work in a lat-lon mapset.
>Harm Olthof (holthof@ecnsun.ecn.nl)Harm;
s.to.rast worked fine for me with a lat.long mapset just be sure
that when the site data is imported it is long|lat|#site format. Complete with
the vertical bars and # sign if you want the sites to be labeled so. See
section 7 of the programmers manual and the s.to.rast man page.Craig
That is strange, I used the correct site format, but all s.to.rast gives me
is a raster file with something like 5 isolated cells in it.
Meanwhile I solved the original problem by chopping the file im three chunks
of ca. 50000 sites. It would still be nice to know what the upper limit would be.
Ahhhh you must set your cell resolution finer, if two cells fall in the same
grid cell only the last value will be assigned to that cell and the previous
value will be lost. For my meterological sites, I finally had to go to 1
minute resolutin to get the s.to.rast to work well.
What I do is
- s.menu option 4 to show duplicate sites.
- s.menu option 7 to generate a frequency raster
- r.out.ascii to a file that is accessed by fortran to count up the greater
than one occurances. Multiple values in a cell.
- correct any problems
- s.to.rast at a fine enough resolution
- r.out.ascii to show the total number of sites a a cross check. This file
can get large so be careful if you have many sites. I use r.out.ascii -1lgz.
I realize it is cumbersome and that a program like proprietary-info would do
it faster with less trouble but then again its not public domain. Anyway once
your sites are rasterized, they should be done once and for all.
Craig
