s.menu
I need something that works like the "site characteristics report" in
s.menu but I want to include a radius around the site not a square.
I can't get away with just r.buffer because the buffers run together
and I'd have to sort out the sites to avoid overlap. I was hoping to
modify the code in s.menu to do a "circle" (I know it won't be a real
circle because it's a raster map) instead of a square, but I couldn't
figure out where it learns which cells to run stats on. I could
figure out a way to do it if I just had one site map to do this to,
but I have hundreds. What I want to do is describe the vegetation in
an error polygon around aerial telemetry locations. My veg map has a
resolution of about 3 m and the error polygon has a radius of 280 m.
If two sites fall in the same place I want to sample that area twice.
So if somebody could point me to the files in s.menu that I'd need to
change or figure out a slick way I could do this and repeat it for
many sets of sites, I'd be eternally grateful. Left to my own
devices I'll probably try something with r.mapcalc and r.stats.
Thanks. Erin O'Doherty /s=e.odoherty/ou=r02f06a@mhs-fswa.attmail.com
