s.surf.tps for only 60 sites?
Fred Watson wrote
I'm trying to perform spline interpolation over about sixty rainfall stations
to construct a rainfall map using s.surf.tps. I get a raster map with only
one category. I'm generally using default parameters.
Any ideas on what the problem is? i.e. why I only get one category.
Thanks in advance,
P.S: Whilst s.surf.tps is running, I also get a stack of warnings about
site descriptions not beginning with '#'. I assume my site file is in order
because s.surf.idw works fine. There is also a warning about 'minimum number of
sites'.
Fred Watson
PhD student
Cooperative Research Centre for Catchhment Hydrology
Civil & Env. Eng. Dept.
Univ. of Melb.
Parkville 3052 Australia
Fred the message about the "#" is correct for using s.surf.tps all your sites descritions should be preceded with a "#", the s.surf.tps will word fine
Use awk for inserting the "#"
awk '{print $1"|"$2"|#"$3}' <infile >outfile
This will do the job
Ronnie Lassche
