s.surf.tps on Linux
Dear grass-users,
I am running Grass 4.15 (Kang's binary) on a Linux 2.0 version. Building up
a DEM from Arc/Info-data (contour-lines), I used r.surf.contour and
s.surf.idw. This works, but I'm not satisfied by the quality of the results.
So I tried s.surf.tps and I got the message:
warning: there are pionts outside of region - will ignore
warning: strip exists with insufficient data
warning: there are points outside specified region - ignored n (nearly all)
points
error: zero points in the given region
- Input data format: 4434015 5628645 #44000
- there are any #0 values
- the region is set to default
Does anyone know about this problem?
Thanks
        Frank
Frank Lederer phone: 069/ 4960545
Sandweg 64
60316 Frankfurt/Main
Germany
