s.surf.tps
Subject problem:
    Recently we send an e-mail message out concerning s.surf.tps.
We did receive some help on the problem and was suggested to get the following
files:
   all the files in directory
   grass/grass4.0/updates/src/libes/bitmap
and file:
   grass/grass4.0/updates/src/include/bitmap.h
and make the following change for the file "make.mid"
in the grass/grass4.0/updates/src/CMD/generic directory
CFLAGS = $(COMPILE_FLAGS) $(EXTRA_CFLAGS) -I$(INCLUDE_DIR) $(USE_TERMIO)
INCLUDE_DIR = $(SRC)/include
BITMAPLIB = $(LIBDIR)/libbitmap.a`
We complied again as sugguested and an error happen.
root@rsgis3> /usr/local/bin/gmake4.0
  SRC = /usr6/local3/grass4/grass4/src
  CMD = /usr6/local3/grass4/grass4/src/CMD
  HEADER = sun4
  ARCH = sun4
  GISBASE = /usr6/local3/grass4/sun4
  VERSION = 4.0 Summer 1991
/usr6/local3/grass4/grass4/src.alpha/sites/s.surf.tps
  make -f OBJ.sun4/make.rules
cc -s OBJ.sun4/main.o OBJ.sun4/data.o OBJ.sun4/quad.o OBJ.sun4/user1.o OBJ.sun4/user2.o OBJ.sun4/user3.o OBJ.sun4/user4.o /usr6/local3/grass4/grass4/src/libes/LIB.sun4/libbitmap.a /usr6/local3/grass4/grass4/src/libes/LIB.sun4/libgis.a -lm
ld: Undefined symbol
   _link_new
   _link_set_chunk_size
   _link_dispose
   _link_cleanup
   _link_init
*** Error code 2
make: Fatal error:
Command failed for target `/usr6/local3/grass4/sun4/etc/bin/alpha/cmd/s.surf.tps'
  It complied ok for a while but failed when it could not defined the symbols in the linkm.h
script.
  Any help would be appreciated from us.
              Thank you,
                 Daniel H. Rodriguez
                 Texas A&M University
