s.surf.tps
Martin are you using the new or old s.surf.tps?
  The new one by now (s.surf.2d from /grass/incoming/interp_lib_new.shar)
raster files with all zeroes can occur if your data are floats
0-1 and integers make them all zeroes. It is possible that your
new data set needs completely different parameters than what
you were using before and that's why you are getting the visible segments.
(for visible segments increase npmin - with old s.surf.tps you
can go up to about 350, with new one, I have used npmin for some
very bad data as large as 600 with good results).
  Well, I'm still at the same point - nothing but zeroes.
  My site file looks like this:
  619946.25|4176606.87|#58000
  619943.75|4176615.62|#58000
  619929.37|4176638.12|#58000
  619904.37|4176671.87|#58000
  619893.75|4176681.87|#58000
  619893.75|4176709.37|#58000
  619893.75|4176771.87|#58000
  (that's file sh2, heights in cm)
  The region is as follows:
  north: 4179364.07936508
  south: 4176563.19047619
  east: 621668.20404722
  west: 619370.06576728
  nsres: 20.00634921
  ewres: 19.98381113
  rows: 140
  cols: 115
  and the history of the elevation file looks like this:
  Thu Aug 11 17:28:05 1994
  e2
  PERMANENT
  ma
  raster
  site file sh2
  generated by s.surf.2d
  tension=40.000000, smoothing=0.100000
  dnorm=15705.616146, dmin=9.991906, zmult=0.010000
  segmax=40, npmin=200, errtotal=0.000000
  zmin_data=0.000000, zmax_data=0.000000
  zmin_int=0.000000, zmax_int=0.000000
  You'll notice that zmin_data and zmax_data are zero.
  I've run the same thing through the old s.surf.tps. That gives me a
  file without obvious segmentation, but with weird values (not a lot of
  connection to the site values). The history of this file is:
  (I've changed the resolution to 50m from 20m above)
  Thu Aug 11 17:55:33 1994
  e3
  PERMANENT
  ma
  raster
  site file sh2
  generated by s.surf.tps
  tension=40.000000, smoothing=0.000000
  dnorm=1002.899713, dmin=24.979764, zmult=0.010000
  segmax=40, npmin=150, errtotal=0.000000
  zmin_data=0.000000, zmax_data=860.000000
  zmin_int=-3532.220660, zmax_int=6055.869155
  Increasing the tension to 80 yields:
  Thu Aug 11 18:27:18 1994
  e4
  PERMANENT
  ma
  raster
  site file sh2
  tension=80.000000, smoothing=0.000000
  zmin_int=-763.460313, zmax_int=1086.388382
  The actual values in the site file range from 52000 to 92000.
  I guess the high values are cut of by dmin, but there's definitely
  no value lower than 52000 (or 520 with zmult) in the site file.
  (sh2 contains 4672 points of which 3714 are ignored due to dmin).
If you cannot get reasonable results from your data set it would be better
if you send us the data and region information so that we can find
out where the problem is. You can try to run s.surf.tps on your
old data set or any other data you have to see whether your installation
of program works OK.
  I can send you any information you need, but as yet I can't seem
  to get any useful output from s.surf.tps and friends :frowning:
  Martin
