It's quite simple Ross: for historical reasons (a miscommunication between
CERL people) the sitefile to input into s.surf.tps has the format
easting|northing|#value
ie the third field has hashes prefixed. Yes, this does make it different
and incompatible with s.surf.idw. I understand that by GRASS-5 this will
all be cleared up (and hopefully the whole sites schemozzle will be much
cleaner, thanks to Darrell McCauley's new specification).
Good luck
Simon Cox
At 8:58 AM 12/4/95 -0500, Ross Searle wrote:
I am trying to generate a DEM using s.surf.tps however the resulting raster
always has a category value of "0" and a label of "no data". However when I
run the same sites list through s.surf.idw it appears to generate a sensible
surface. The format of my sites list is :-name|sitetest
desc|test for sites list from contpts
377395|7092510|480
377461|7092519|480
377506|7092531|480
377581|7092606|460
etcWhen I run s.surf.tps the following error messages for each site are
displayed before it continues processing:-eg " 400 (line 484) site description not prefixed with '#'"
Does anyone know where I might be going wrong !
Ross Searle
##################################################################Ross Searle Dept of Primary Industries
Land Resources Officer PO Box 1143
Bundaberg, 4670. QLD
rossse@dpi.qld.gov.au
PH (071) 537 888 FAX (071) 537 895##################################################################
___________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox@dem.csiro.au W
AGCRC info>> http://www.dem.csiro.au/simon/crc/intro.html
