s.surf.tps
I am trying to generate a DEM using s.surf.tps however the resulting raster
always has a category value of "0" and a label of "no data". However when I
run the same sites list through s.surf.idw it appears to generate a sensible
surface. The format of my sites list is :-
name|sitetest
desc|test for sites list from contpts
377395|7092510|480
377461|7092519|480
377506|7092531|480
377581|7092606|460
etc
When I run s.surf.tps the following error messages for each site are
displayed before it continues processing:-
eg " 400 (line 484) site description not prefixed with '#'"
Does anyone know where I might be going wrong !
Ross Searle
Ross Searle Dept of Primary Industries
Land Resources Officer PO Box 1143
                                        Bundaberg, 4670. QLD
rossse@dpi.qld.gov.au
PH (071) 537 888 FAX (071) 537 895
"""When I run s.surf.tps the following error messages for each site are
Does anyone know where I might be going wrong !"""
Well, exactly what the message says: your file has to be like:
377395|7092510|#480
377461|7092519|#480
etc.
The # means that 480 is a number and not a category label.
Good luck!
Agus
