s.to.labels
Hello grasshoppers,
the following message contains a script wich can be used for transforming a sites file into a label file wich can be used wich the commands like d.paint.label and d.labels
__________________cut here_______________________
#program made by Ronnie Lassche on the may 24
#user can transform a sites file into a label file
#for comment mail to lasm@geo.vu.nl
echo "Option: Name of sites file"
echo " key: file"
echo "required: YES"
g.ask type=old element=site_lists desc="sites" unixfile=/tmp/$$
eval `cat /tmp/$$`
sitelist="${name}"
rm -f /tmp/$$
  if [ ! "$file" ]
   then
     exit 0
  fi
echo ""
echo "Option: Name of resulting label file"
echo " key: file"
g.ask type=any element=paint/labels desc="label file" unixfile=/tmp/$$
eval `cat /tmp/$$`
labelfile="${name}"
rm -f /tmp/$$
  if [ ! "$file" ]
   then
    exit 0
  fi
gotit=0
while test $gotit -eq 0
do
echo ""
echo "Option: Relative position"
echo " key: ref"
echo " Default: center"
echo "required: NO"
echo -n "enter option > "
read refpos
  if test "$refpos"
   then
    if test "$refpos" != "lower left" -a "$refpos" != "lower right" -a "$refpos" != "lower center" -a "$refpos" != "upper left" -a "$refpos" != "upper right" -a "$refpos" != "upper center" -a "$refpos" != "center"
     then
      echo ""
      echo "sorry <$refpos> is not valid input"
      echo ""
      echo "options : lower left,lower right,lower center"
      echo " upper left,upper right,upper center,center"
     else
      gotit=1
    fi
   else
    refpos=center
    gotit=1
  fi
done
gotit=0
do
  echo ""
  echo "Option: Text color "
  echo " key: color"
  echo " Default: black"
  echo "required: NO"
  read color
   if test "$color"
    then
     if test "$color" != "aqua" -a "$color" != "black" -a "$color" != "blue" -a "$color" != "brown" -a "$color" != "cyan" -a "$color" != "gray" -a "$color" != "green" -a "$color" != "grey" -a "$color" != "indigo" -a "$color" != "magenta" -a "$color" != "orange" -a "$color" != "purple" -a "$color" != "red" -a "$color" != "violet" -a "$color" != "white" -a "$color" != "yellow"
      then
       echo ""
       echo "sorry <$color> is not valid input"
       echo ""
       echo "Options : aqua,black,blue,brown,cyan,gray,green,grey,indigo,"
       echo " magenta,orange,purple,red.violet,white,yellow"
      else
       gotit=1
     fi
    else
     color=black
     gotit=1
   fi
  done
gotit=0
do
  echo ""
  echo "Option: Size of text (pixels) "
  echo " key: size"
  echo " Default: 10"
  echo "required: NO"
  read size
   if test "$size"
    then
     if test $size -le 0
      then
        echo ""
        echo "sorry <$size> is not valid input"
        echo ""
        echo "size must be greater then 0"
      else
       gotit=1
     fi
    else
     size=10
     gotit=1
  fi
done
gotit=0
do
  echo ""
  echo "Option: Width of text (pixels) "
  echo " key: size"
  echo " Default: 1"
  echo "required: NO"
  read width
   if test "$width"
    then
     if test $width -le 0
      then
        echo ""
        echo "sorry <$width> is not valid input"
        echo ""
        echo "width must be greater then 0"
      else
       gotit=1
     fi
    else
     width=1
     gotit=1
  fi
done
gotit=0
do
  echo ""
  echo "Option: Background color "
  echo " key: background"
  echo " Default: none"
  echo "required: NO"
  read back
   if test "$back"
    then
     if test "$back" != "aqua" -a "$back" != "black" -a "$back" != "blue" -a "$back" != "brown" -a "$back" != "cyan" -a "$back" != "gray" -a "$back" != "green" -a "$back" != "grey" -a "$back" != "indigo" -a "$back" != "magenta" -a "$back" != "orange" -a "$back" != "purple" -a "$back" != "red" -a "$back" != "violet" -a "$back" != "white" -a "$back" != "yellow" -a "$back" != "none"
      then
       echo ""
       echo "sorry <$back> is not valid input"
       echo ""
       echo " magenta,orange,purple,red.violet,white,yellow,none"
      else
       gotit=1
     fi
    else
     color=none
     gotit=1
   fi
  done
gotit=0
do
  echo ""
  echo "Option: Border color "
  echo " key: border"
  echo "required: NO"
  read border
   if test "$border"
    then
     if test "$border" != "aqua" -a "$border" != "black" -a "$border" != "blue" -a "$border" != "brown" -a "$border" != "cyan" -a "$border" != "gray" -a "$border" != "green" -a "$border" != "grey" -a "$border" != "indigo" -a "$border" != "magenta" -a "$border" != "orange" -a "$border" != "purple" -a "$border" != "red" -a "$border" != "violet" -a "$border" != "white" -a "$border" != "yellow" -a "$border" != "none"
      then
       echo ""
       echo "sorry <$border> is not valid input"
       echo ""
      else
       gotit=1
     fi
    else
     border=none
     gotit=1
   fi
  done
gotit=0
do
  echo ""
  echo "Option: opaque (yes/no)"
  echo " key: opaque"
  echo " Default: no"
  echo "required: NO"
  read opaque
   if test "$opaque"
    then
     if test "$opaque" != "yes" -a "$opaque" != "no"
      then
       echo ""
       echo "sorry <$opaque> is not valid input"
       echo ""
       echo "Options : yes,no"
      else
       gotit=1
     fi
    else
     opaque=no
     gotit=1
   fi
  done
gotit=0
do
  echo ""
  echo "Option: Fontname "
  echo " key: font"
  echo " Default: romans"
  echo "required: NO"
  read font
   if test "$font"
    then
     if test "$font" != "romans" -a "$font" != "romanc" -a "$font" != "romancs" -a "$font" != "romand" -a "$font" != "romanp" -a "$font" != "romant" -a "$font" != "italicc" -a "$font" != "italiccs" -a "$font" != "italict" -a "$font" != "gothitt" -a "$font" != "gothgrt" -a "$font" != "gothgbt" -a "$font" != "scriptc" -a "$font" != "scripts" -a "$font" != "greekc" -a "$font" != "greekcs" -a "$font" != "greekp" -a "$font" != "greeks" -a "$font" != "cyrilc"
      then
       echo ""
       echo "sorry <$font> is not valid input"
       echo ""
       echo "Options : cyrilc,gothgbt,gothgrt,gothitt,greekc,greekcs,"
       echo " greekp,greeks,italicc,italiccs,italict,romanc,"
       echo " romancs,romand,romanp,romans,romant,scriptc,scripts"
      else
       gotit=1
     fi
    else
     font=romans
     gotit=1
   fi
done
gotit=0
do
  echo ""
  echo "Option: xoffset (pixels) "
  echo " key: pixels"
  echo " Default: 0"
  echo "required: NO"
  read xoff
   if test "$xoff"
    then
       gotit=1
    else
     xoff=""
     gotit=1
  fi
done
gotit=0
do
  echo ""
  echo "Option: yoffset (pixels) "
  echo " key: pixels"
  echo " Default: 0"
  echo "required: NO"
  read yoff
   if test "$yoff"
    then
       gotit=1
    else
     yoff=""
     gotit=1
  fi
done
echo "#!/bin/sh" > /tmp/$$
echo "cat $LOCATION/site_lists/$sitelist | sed 's/#//g' | awk '" >> /tmp/$$
echo "{" >> /tmp/$$
echo "{FS = \"|\"}" >> /tmp/$$
echo "{print \"east: \"\$1}" >> /tmp/$$
echo "{print \"north: \"\$2}" >> /tmp/$$
echo "{print \"xoffset: $xoff\"}" >> /tmp/$$
echo "{print \"yoffset: $yoff\"}" >> /tmp/$$
echo "{print \"ref: $refpos\"}" >> /tmp/$$
echo "{print \"font: $font\"}" >> /tmp/$$
echo "{print \"color: $color\"}" >> /tmp/$$
echo "{print \"size: $size\"}" >> /tmp/$$
echo "{print \"width: $width\"}" >> /tmp/$$
echo "{print \"background: $back\"}" >> /tmp/$$
echo "{print \"border: $border\"}" >> /tmp/$$
echo "{print \"opaque: $opaque\"}" >> /tmp/$$
echo "{print \" \"}" >> /tmp/$$
echo "{print \"text:\" \$3}" >> /tmp/$$
echo "'} > $LOCATION/paint/labels/$labelfile" >> /tmp/$$
chmod u+x /tmp/$$
/tmp/$$
rm /tmp/$$
* Ronnie Lassche *
* Department of earth sciences *
* Free University *
* Amsterdam *
* lasm@geo.vu.nl *
