#1810: AdhocVM not accessible
Reporter: jmckenna | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jmckenna):
Great work Martin! Sounds tricky!!!! Looks good here, I'm able to login
and start the MapServer services. Do you think we should add any notes
about this issue (for next time) to the wiki?
https://wiki.osgeo.org/wiki/AdhocVM
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1810#comment:20>
OSGeo <http://www.osgeo.org/>
Keywords: |
Comment (by martin):
Hi Jeff, I'll add my notes to the Wiki after the result proved to be
reproducible on a different VM.
I've just issued another reboot on the "adhoc" VM in order to test, wether
standard system-, kernel- or bootloader-upgrades are safe. Apparently they
are.
Thus if you still require manual intervention to start services after
reboot, please go ahead now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1810#comment:21>
Keywords: |
thanks Martin, I've restarted the MapServer services.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1810#comment:22>
Keywords: |
Comment (by strk):
Jeff can this be closed then ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1810#comment:23>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jmckenna):
* status: new => closed
* resolution: => fixed
Comment:
of course, thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1810#comment:24>
