Lance,
By RAID0 I meant by what you suggested below:
>> Unfortunately, the disk controllers technically don't support JBOD,
>> however we can work around it by setting up each disk as a RAID0
>> device. This is what we do our Ceph storage nodes and it works
>> quite nicely. It also allows the disks to use the HW RAID cache.
As for the OS that won't be under ZFS will a regular extfs partition, so maybe a RAID1 (is that what you were suggesting)?
I suppose having some level of redundancy for the root partition would be good since we won't have that under ZFS.
Hope that clarifies things,
Regina
-----Original Message-----
From: Sac [mailto:sac-bounces@lists.osgeo.org] On Behalf Of Lance Albertson via RT
Sent: Monday, August 26, 2019 12:51 PM
To: michael.smith.erdc@gmail.com; tech@wildintellect.com
Cc: sac@lists.osgeo.org; rootmail-students@osuosl.org; tech_dev@wildintellect.com
Subject: [SAC] [support.osuosl.org #30704] OSGeo Server Parts Order
On Mon Aug 26 09:39:48 2019, lr@pcorp.us wrote:
Sorry I guess I missed all this discussion.
For the OSGeo7 we had 500GB allocated for root, and the rest of the
disks were set aside for ZFS.
I think a similar setup will work. Note the 500 GB is useful for
exporting images so I'd like at least that much separate from our lxd
ZFS pool. It doesn't need to be the root drive and doesn't really need mirroring either.
I think going with RAID0 is probably the best. Also last time we did
this -- you just inserted the Ubuntu 18.04 disk in the CD tray and we
took care of the installation. Not sure if that is doable or if
because of the way the RAID is setup that's not doable.
Based on what I mention below, how do you want the physical disks setup with regards to the HW RAID? Should the rootfs, should that have any RAID and if so what? You mentioned RAID0 above, I wasn't sure for which volume. Also, I'm not sure how OSGeo7 was configured as far as HW RAID and disks.
Thanks-
>> So it sounds like you want the server setup with a JBOD (just a
>> bunch of
>> disks) effectively making each disk visible for ZFS and no HW RAID.
>> Do you want me to attempt to do a rootfs on ZFS or try and keep it
>> simple and just do a RAID1 with the first partition on two or more
>> drives, and leave the rest of the drives for ZFS?
Lance Albertson
Director
Oregon State University | Open Source Lab _______________________________________________
Sac mailing list
Sac@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/sac
