Scanning maps into GRASS
I also do this, with topo maps. A 256 color scan is usually enough, then a
bit of playing with pallettes if I have multiple tiles, to make sure the
pallettes are the same.
A bitmap editor on the PC with the scanner help me take off the text, but
I usually use these maps only as backdrops for reference, not as an
information source.
I can't think of a better way, really. The color and area accuracy I
demand of this process is relatively low, as long as they end up in the
right place.
Angus.
On Tue, 23 Jul 1996, R.A.Sanderson wrote:
Does anyone have experience of using a flatbed scanner (e.g. HP ScanJet) to
scan colour maps from paper, and convert them into GRASS raster maps
(running GRASS on SunOS). I have managed to get a simple test map,
containing only 2 colours, into GRASS, via r.in.sunrast, but it has proved
very difficult to clean up the image, to remove speckles without changing
the total areas of each scanned colour. I've tried using r.buffer and
r.neighbours, together with r.mapcalc. The main problems are associated
with text on the map resulting in a "noisy" image, and editing out these
points using d.rast.edit is too slow to be practical.
Thanks
Roy
Roy Sanderson
Centre for Land Use and Water Resources Research
Porter Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 222 7789
Fax: +44 191 222 6563
URL: http://www.cluwrr.ncl.ac.uk
