Hi to all Grassuser,
I can't use r.in.tiff (nor all related scripts like r.in.arctiff)
because it cause a Segmentation fault.
I use Grass 4.21 with Linux-RedHat 5.2
Any suggestion?
TIA
franz
Any suggestion?
TIA
franz
Do you have the libraries (like libtif.a and all the others) required
for most programs that do conversions to/from tiff format? These might
be required by Grass to use the modules you mention (they should be
available using your Red Hat CD and the RPM) and might not be installed
by default.
