I'm having a little trouble translating the following projection info
from Arc/Info, into a grass location.
Teale Albers projection parameters:
projection albers
units meters
parameters
1st Standard Parallel: 34 00 00
2nd Standard Parallel: 40 30 00
Central Meridian: -120 00 00
Latitude of origin: 00 00 00
False easting (meters): 0
False northing (meters): -4000000
Datum: NAD27
Spheroid: Clarke 1866
My questions are:
1) What does grass mean by Central Parallel? I guessed at giving the
difference between the 1st and 2nd parallels. But...
2) How would I set the latitude of origin as the equator?
3) How do I set a false northing?
4) There doesn't seem to be anywhere to set the datum. Is NAD27
assumed under aea?
Thank you all, especially those who helped me with compilation problems.
Eric G. Miller
Powered by the POTATO (http://www.debian.org)!
