settings for ImageAlchemy & NovaJet?
Malcolm-
Use the following command line for Image Alchemy PS:
alchemy --r10 -Ze1 -Zf1 -Zm2 <in.psfile> <out.rtlfile>
Make sure the following variables are set:
ALCHEMYPS (which points to alchemy_install_dir/ps directory)
Mark Gibb
USACERL
----- Begin Included Message -----
From grass-lists-owner@max.cecer.army.mil Mon Oct 30 13:13:09 1995
Date: Mon, 30 Oct 1995 12:55:06 -0600 (CST)
X-Sender: malcolm@cast
Sender: grass-lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
Subject: settings for ImageAlchemy & NovaJet?
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
Content-Length: 569
Hi
Does anyone out there use Image Alchemy to convert ps.map-generated files
to print on an Encad NovaJet II inkjet plotter? If so, would you be so
kind as to pass on the parameters that you are using with Image Alchemy
to get satisfactory images? Thanks for any and all help!
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
----- End Included Message -----
