Hello,
I am trying to run SG3d. I get the following error and SG3d will
not run.ERROR: GISRC - variable not set
Can anyone tell me what this GISRC variable is? Thanks.
-Stephen Dzurenko
$GISRC is set when you start up GRASS; the variable $GISRC is a file in
your home-directory where information concerning your GRASS setup is
stored. It's usually called $home/.grassrc and contains indispensable
information like the GISDBASE, LOCATION_NAME and MAPSET variables that
GRASS needs in order to find your maps. I seem to remember a discussion
on this list a long, long time ago about starting GRASS programs outside
the GRASS-shell; maybe there's someone with a fresher memory than mine
that can tell us more about that.
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@hacktic.nl
