SG3d
Hello,
I am trying to run SG3d. I get the following error and SG3d will
not run.
ERROR: GISRC - variable not set
Can anyone tell me what this GISRC variable is? Thanks.
-Stephen Dzurenko
$GISRC is set when you start up GRASS; the variable $GISRC is a file in
your home-directory where information concerning your GRASS setup is
stored. It's usually called $home/.grassrc and contains indispensable
information like the GISDBASE, LOCATION_NAME and MAPSET variables that
GRASS needs in order to find your maps. I seem to remember a discussion
on this list a long, long time ago about starting GRASS programs outside
the GRASS-shell; maybe there's someone with a fresher memory than mine
that can tell us more about that.
The last GrassClippings has this information provided by W. Frederick Limp
and Malcom Williamson.
"1. set the following environmental variables:
GISRC(should be your_home_dir_path/.grassrc)
GISBASE (where the GRASS bin, etc, and scripts directories are found)
GIS_LOCK (usually set to the processid of the start up shell script: I
would use the pid of the current shell)
GISDBASE (the database entry on the GRASS start up page )
LOCATION (the Database and the location of the mapset)
MAPSET (just the mapset name)
Add the following paths to your PATH:
$GISBASE/bin
$GISBASE/scripts
$GISBASE/garden/bin
If these are set you can type any GRASS caommand and it should execute."
I have done this in a shell script and it has worked without any problems.
  Rebecca Scheckler rebecca@vt.edu(internet)
  Senior Programmer/Analyst rebeccas@vtvm1(bitnet)
  Information Systems and Insect Studies fax: 703-231-9131
  Virginia Tech phone: 703-231-7216
  Blacksburg, VA 24061-0319
