In an E-mail message, Amy Keeley wrote:
Hello,
I have several vector, site,
and raster files under a certain
mapset that I want other people
logged in as a different user
to have access to. I have used
Unix chmod, and also g.access, but
nothing seems to work. They still
get a message when entering grass
with the specific mapset chosen that
they do not have access to this mapset.
Do I really have to go in and create
a new mapset and copy all of the files
to that directory? It seems like such
a waste of space.Any help would be appreciated,
Amy K. Keeley
akeeley@ncdc.noaa.gov
Amy,
Have you used the g.mapsets command yet. This command allows you to add or
delete mapsets to your mapset search path. This search path exists then as
a file in your Grass home directory as SEARCH_PATH. Thus you can edit this
file directly or use the g.mapsets command to do it for you.
Paul Loechl p-loechl@cecer.army.mil
USA CERL (217)352-6511x7668
