shell scripts in GRASS4.1
Try running the unix command rehash .
Don't ask me what it does. But it fixes
that problem for me. If that doesn't work
make sure that . (current directory) is in
you path setting. For a test try running the
shell script as ./script . If that works
then your path setting doesn't have the current
directory (or . ) in it.
Mark Johnson
USACERL
