I have a raster file that I want to shift or move all the cells a specific
distance. For example
I want to move all the cells 1 degree latitude north, and 1 degree
longitude east. Does anyone
know how to do that?
Any help is appreciated.
Thank you.
All you should have to do is edit the cellhd file and add (or subtract) the
appropriate amount of 'shift' you want to make in your data matrix. Just be
sure to make the same amount of 'shift' (e.g., x meters) in both the North
and the South values. Similarly, you must also make the same amount of 'shift'
(e.g., y meters) in the West and East values. The shift values of x and y,
however, do NOT have to equal one aonther.
Such a procedure will not necessitate a change in the x or y resolution. And,
of course, the number of rows and columns in the data matrix will NOT change.
I am not certain why you would want to do the above, but as far as GRASS is
concerned, it will work.
Mark Gregory mg@soil.agr.okstate.edu
Oklahoma State University 405-744-6417
Stillwater, OK 74078-6028 405-744-5269 (fax)
