Simon Cox (simon@artemis.earth.monash.edu.au) writes on 6 Jan 94:
>Philip Verhagen wrote:
>>. By the way, to my knowledge the concept of
>> 'attribute of a site_list' is not very clear in GRASS. Some programs (like
>> s.surf.tps) assume that you have a 'real' attribute when its preceded by a
>> #, and otherwise it's considered a comment.
>I agree that this is not clear, and not clearly documented either!In the case of s.surf.tps, there's no apparent reason why the '#' is
needed. Other programs like s.menu (the conversion) and s.voronoi
use the silly '#' (to some extent).I've hacked on the man page sites.format to clear things up a little.
If others want to whack at it, get it from
pasture.ecn.purdue.edu:pub/mccauley/grass/sites.format,
make whatever additions/deletions you see fit, and send
it to olga or someone (grassbug@zorro).--Darrell
It looks to me like Darrell and Helena are the two people currently most active
programming s.progs. Is it possible for a definitive decision to be made
by them, and then ratified by CERL? It looks like one of you will have to
change,
as I think the use of # to indicate a code or an attribute is different between
you (eg s.surf.tps vs s.sample).
Just my farthing's worth
Simon
___________________________________________________
__ L Dr Simon Cox
,~' L_|\ VIEPS Department of Earth Sciences,
,-' \ Monash University, Clayton Vic 3168
( \ Australia
\ ___ / Phone +61 3 905 5762
L,~' "\_x/ Fax +61 3 905 5062
u simon@artemis.earth.monash.edu.au
