site.to.vector.to.rast
I would like to build a raster layer from valued site data after using the
s.voronoi option in geom to generate polygons around each site. So far,
my approach has been to:
1) create an ASCII site file with category values and labels.
2) use s.in.ascii to convert it to a GRASS site list.
3) apply the voronoi tesselation in geom to the site list to produce
    the vector layer.
Now, how can I produce a raster layer that assigns a site's value to all of
the cells contained within that site's polygon?
Thanks in advance for your help,
Cliff Behrens
Cliff
Here is what I did.
  1. v.support
  2. v.digit - close polygons by breaking lines and snapping in the
                     edit menu, and then labelling the areas.
  3. v.to.rast
Richard Beecham email:beecham@aerg.canberra.edu.au
Hydrology Unit phone:(02) 895 7169
NSW Department of Water Resources fax :(02) 895 7834
Parramatta NSW 2124
Australia
    the vector layer.
Cliff Behrens
If you have true polygons, ie areas, the site list can be fairly easily
converted to a list of area labels. Have a look at existing files in the
$LOCATION/dig_att directory for the proper format. If the polygons are
not true areas, you would need to do some editing - I can supply further
details if necessary. Once the dig and dig_att files are OK you can run
v.support and v.to.rast on the map.
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam
martijn@scanner.frw.uva.nl
