sites to raster
Is there a way to convert a sites list to raster so as to keep the attributes
of the sists lists intact? When I go through s.menu all I get is a 0/1
image.
here goes,
     " You can create a non-binary raster map
      layer representation of your site list by creating the site
      list in the format:
        E|N| #n label
      where E is the Easting, N is the Northing, and #n label is
      the description field. The description field consists of a
      pound sign # followed by the category value n to be
      associated with the site's cell location, and the category
      label label for n.
      If the user does not include a description field starting
      with
        #n
      beside the Easting and Northing on every line in the sites
      list file, a binary raster map layer will be created
      instead. In the binary raster file, each site will be
      represented as the category value 1. Non-site cells will...."
                                  - g.manual
Hope this helps,
R. Brian Culpepper Research Assistant
Center for Advanced Spatial Technologies (fax) 501 575-3846
Rm. 214 Ozark Hall (work) 501 575-6159
University of Arkansas brian@cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
