James Darrell McCauley writes:
Does anyone (particularly in Europe) use non-US (8-bit) characters in
site lists? If so, would you mind uuencoding a sample file (< 50
lines) and sending it to me (along with DEFAULT_WIND). I would like
to test some sites software. Thanks,
Obviously you are aware that the incorporation of
so-called diacritic signs under UNIX is still problematic for a lot of
software, including GRASS and INFORMIX which I have been using
exclusively for the creation of a French sites database. The French were
only mildly annoyed at the impossibility of including accents, and we
spent several weeks exchanging diskettes (by snail-mail, not everyone is
on the net) trying to find out how to convert their data, in
MacIntosh format, to UNIX-compatible format. So if you're planning to
incorporate the extended ASCII set in GRASS, I am definitely in favour!
I'll send you a file a.s.a.p.!
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
