This problem shows you are using a 24 bit colour map.
Switch the Xserver (openwindows) to an 8-bit mode and it will work in all
of the below cases.
X uses a colour map only in 256 colour map, and GRASS demands a colour
map. XDRIVER24 is a hack to use a 24bit display. It's a working hack,
however.
Angus Carr.
On Thu, 6 Feb 1997 gomlra3!ohler@atlas.il.nrcs.usda.gov wrote:
Hello Grass users --
I am running GRASS 4.1 update 5 on a sparc 5 with Solaris
2.5.1. After compiling and recompiling the XDRIVER I
still get the following error when executing d.mon:X Error of failed request: BadMatch (invalid parameter attribute)
Major Opcode of failed request: 78 (X_CreateColorMap)
Serial Number of failed request: 229
Current serial number in output stream: 230Poking around on the moon.ftp site I found a different XDRIVER
called XDRIVER24. I went ahead and compiled that one, and I
am able to use it for the display device. However, this driver
does not allow floating point colormode.As an additional indicator there is something off on the machine,
two related software packages have the same problem:- When trying to start LT Plus (compiled on site),
I get an identical error to the one above.- When starting Grasslands (obtained from ftp site),
an information box indicates the inability to create
the colormap, then exits.I would like to know if anyone has seen this before,
and could suggest a remedy.I appreciate your help...
Eric Ohler
USDA - NRCS
