Hi. I'm attempting a data transfer from SPANS5.3 to
GRASS4.1. So far, I've exported a file from SPANS
into the ASCII DLG format. After attempting to
pull this into GRASS with v.import, I get a message
that states, "Error reading DLG header." Can anyone
help me?
NOTE: The outputs from the SPANS are actually two
files: filename.VEH and filename.VEC. I'm assuming
that the .VEH file is a header file and the .VEC file
is the vector file. Now, how do I combine the two
of these so that v.import can read them both??
Thanks in advance,
Amy Keeley akeeley@ncdc.noaa.gov
