Sorry to waste the bandwidth because an unreachable
individual E-Mail address.
Song
I would appreciate that driver you mentioned because we've
had trouble with the MAPGEN ps driver. I would also like
to benefit from the options you have added in your driver.Thanks for the help,
Jim
jim@sar_ws.fb4.noaa.gov
This is a C-shell script, you may need to modify on your site.
If you have questions about it, please let me know.
Cut following section out and save it with a file name post.sh.
Change permission to executable, then should be able to run it.
Song Wang
CAST/NCRI
University of Arkansas
# * post.sh *
# This script is used to plot MAPGEN
# maps from a PostScript printer
# Command format ---
# post.sh
# Note: To run this program, you have to be in the
# directory: GRASS_data_dir/LOCATION/MAPSET/mapgen/mapname;
# postfile is a new file name defined by
# the user to save PostScript file used to
# draw MAPGEN maps;
# scale_parameter is a real number by which
# the map coordinates are multiplied. It is
# the mechanism used to rescale map prints.
clear
echo " "
echo " "
echo " "
echo " "
echo " Warning "
echo " "
echo " This program is used to create a PostScript file"
echo " for MAPGEN maps and plot the map on a PostScript"
echo " printer across the network. Before you go any "
echo " further, please make sure that GRASS-MAPGEN shell"
echo " has been properly started and you are in the "
echo " correct MAPGEN directory ! "
echo " (GRASS_data_dir/LOCATION/MAPSET/mapgen/mapname) "
echo " "
echo -n " Hit [return] to continue --> "
set oktogo = $<
clear
echo " "
echo " "
echo " "
echo "Do you want to save the PostScript file for"
echo "the MAPGEN plot ?"
echo " "
echo -n "Answer (y or n) --> "
set savefile = $<
if ($savefile =~ y*) then
echo " "
echo " "
echo "Enter a new file name to save the PostScripts"
echo "file for the MAPGEN plot."
echo " "
echo -n "--> "
set postfile = $<
else # Creat PostScript program as a temporary file
set postfile = "temp"
endif
echo " "
echo " "
echo "Enter a scale parameter to resize the map"
echo "prints. This parameter must be a real number"
echo "by which the original map size is multiplied."
echo "(Default value is one that will print the map"
echo "in same size as the original)."
echo " "
echo -n "--> "
set map_scale = $<
if ($map_scale == "") then
set map_scale = "1"
endif
echo " "
echo " "
echo "Do you want to define a new origin for"
echo "your map plot ?"
echo " "
set set_origin = $<
if ($set_origin =~ y*) then
echo " "
echo " "
echo "Enter a number for X coordinate of the origin."
echo "This number ranges from 0 to 4318. "
echo " "
echo -n "--> "
set Xorigin = $<
echo " "
echo " "
echo "Enter a number for Y coordinate of the origin."
echo "This number ranges from 0 to 5588."
echo " "
echo -n "--> "
set R_Yorigin = $<
else
set Xorigin = 200 # default value
set R_Yorigin = 200 # default value
endif # Define a new origin for the map plot
echo " "
echo " "
echo "Do you want to rotate 90 degree for the map plot ?"
echo " "
set map_rotate = $<
# Create PostScript file for MAPGEN plots
# Create PostScript header
if (-e tmp.ps) then
rm tmp.ps
endif
cat /usr2/grass4/sun4/mapgen/interface/postStart > tmp.ps
# Create a primary PostScript file for a MAPGEN plot
if ($map_rotate =~ y*) then
/usr2/grass4/sun4/mapgen/bin/plotter -dr ps -s $map_scale ovm/* >> tmp.ps
else # Do not rotate the map plot
/usr2/grass4/sun4/mapgen/bin/plotter -d ps -s $map_scale ovm/* >> tmp.ps
endif
# Reset origin for the MAPGEN map plot
@ Yorigin = 5588 - $R_Yorigin
if ($map_rotate =~ n*) then
cat tmp.ps | awk '{if ($3 == "translate") {$1=i; $2=l; print} else print}' i=$Xorigin l=$Yorigin > $postfile.ps
else
cat tmp.ps | awk '{if (NR == 11) {print i, l, "translate"} else print}' i=$Xorigin l=$R_Yorigin > $postfile.ps
endif
# Print the MAPGEN PostScript plot
clear
echo " "
echo " "
echo "Your MAPGEN map is plotting off the PostScript printer \!"
rsh spock lp <$postfile.ps
mv $postfile.ps ~/.
else
rm temp.ps
endif
# End of the program
