spectral signatures
Christina Seabra writes:
I would like to use the same regions I've created to classify a certain image in the
classification of another image. This way I Know that the regions used in one
classification will be exactly the same that I'll use when classifying another image.
The problem is, I haven't find any tool in GRASS that does that. Is it possible to do it
some indirect way?
It is very boring having to redraw each region each time I want to classify an image and
it is never exactly the same region.
Any suggestions??
Christina, this is the kind of topic that I would want to include in
my GRASS beginner's Guide. If you think of a solution (or if anybody
emails a solution to you), could you let me know ?
martijn@scanner.frw.uva.nl
