Spot images ?
Hi !
Has anybody experience how to import/access spot images in cap-Format
(preprocessing level 1B) ?
IS it possible via i.tape.other ro something like that ? I tried that,
but could not access the cd-rom drive (though mounted!).
Thanks, Michael
Michael Schulz
Christoph-Mang-Str.5 Geologisches Institut
79100 Freiburg Universitaet Freiburg
                           Albertstr. 23b
                           79104 Freiburg
Michael Schulz wrote:
Hi !
Michael,
I don't have any experience using grass to read spot CAP format, but I am
familiar with the format. I see there is an i.tape.spot program which
looks more appropriate to your needs, have you tried it? It doesn't seem
to have a man page.
If that doesn't work then give me the product type (Xs, Xi, or PAN) and I
will lookup the raw imagery layout information.
.. double take ...
Say, aren't i.tape.other and related programs for accessing real tapes? I
looked at r.in.bin, and it doesn't seem to offer the flexibility to read
CAP format without lots of extra junk around the edges.
In looking briefly at i.in.spot, it seems that the tape access could, with
some work, be hooked to read from the disk files since the CEOS files have
the record lengths in the data.
If there is wide interest, I could likely write an i.in.ceos that would
just capture the raw imagery from the CEOS imagery file on CDROM. This
would cover Spot CAP as well as other products like TM (from some sources),
RadarSat, ERS and so on.
Best regards,
I set the clouds in motion - turned up | Frank Warmerdam, warmerda@home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
Hi
ps.map seems to be outputting postscript maps with a maximum size of 1
letter page. Is it possible to get larger maps out. How do I alter the
panel size for say A0 maps.
Henk
Henk Coetzee
Geophysics Unit
Council for Geoscience
Private Bag X112, Pretoria, 0001, South Africa
Tel: +27-12-841-1192 Fax: +27-12-841-1424
Hello, Henk
You'll need to configure your own device files under
$GISBASE/etc/paint/ps.devices . Look at the ps.select manual page for
further details.
  -Malcolm Williamson
Henk Coetzee wrote:
Hi
Henk
Henk Coetzee
Geophysics Unit
It seems to work OK, except that the A4ish size maps that were working
now contain none of the data that were there before. Is there a
compatibility problem between 4.2 and 5.0beta.
Henk
Malcolm Williamson wrote:
Hello, Henk
further details.
        -Malcolm Williamson
Henk Coetzee wrote:
> Hi
> Henk
> Henk Coetzee
> Geophysics Unit
Henk Coetzee
Geophysics Unit
