starting GRASS
The problem may be with your unix setup. The setting of the TERM
variable to sun-cmd, or sun, or xterm, must refer to a database
of ascii terminal capabilities. These are in the file
/etc/termcap. The other things you tried - XDRIVER, sunview - are
not ascii terminal capabilites, but GRASS graphics drivers so
they aren't appropriate requests. I suspect that your
/etc/termcap either doesn't have sun-cmd or that you have been
bitten by a subtle "feature" of the termcap logic: you also have
the variable TERMCAP set as well. If TERMCAP is set, then Unix
won't look in /etc/termcap but attempt to take its info from what
TERMCAP has. Try this:
  unsetenv TERMCAP # if you are using /bin/csh
  TERMCAP=;export TERMCAP # if you are using /bin/sh
before running grass. Then wahtever you set TERM to look in
/etc/termcap to see that in fact there is entry for the TERM type
you pick.
| I just finished compiling GRASS4.0 on a Sun SPARCstation 1 and have a
|few questions. It starts but I don't get past the start-up screen - the problem
|is with TERM as you can see from the copy of my session (included below). My
|usual environment has term=sun-cmd which doesn't seem acceptable, but then
|nothing else seemed to work either. I looked at
| grass4.0/src/display/devices/monitorcap/monitorcap
|and all entries were commented out so I uncommented the entry for sunview and
|started GRASS again but had the same problem. Did this need to be uncommented
|before I ran GISGEN? Any help would be appreciated.
| Sincerely,
| jack hurlbut
|/* Below is the output from starting GRASS */
|WELCOME TO GRASS Version 4.0 Summer 1991
| 1) Have at your side all available GRASS tutorials
| - For getting started, try to duplicate the session
| outlined in: "GRASS Tutorial: GIS Tool Access"
| 2) When working on your location, the following materials
| are extremely useful:
| - A topo map of your area
| - Current catalog of available computer maps
| 3) Please mail any comments to: cerl!grass
|Hit RETURN to continue
|Type sun-cmd unknown
|TERM = (unknown) vt100
|Type vt100 unknown
|TERM = (unknown) sun
|Type sun unknown
|TERM = (unknown) xterm
|Type xterm unknown
|TERM = (unknown) xterms
|Type xterms unknown
|TERM = (unknown) XTERM
|Type XTERM unknown
|TERM = (unknown) XTERMS
|Type XTERMS unknown
|TERM = (unknown) XDRIVER
|Type XDRIVER unknown
|TERM = (unknown) SUNVIEW
|Type SUNVIEW unknown
|TERM = (unknown) sunview
|Type sunview unknown
|TERM = (unknown) xdriver
|Type xdriver unknown
|TERM = (unknown) openwindow
|Type openwindow unknown
|TERM = (unknown) openwindows
|Type openwindows unknown
|TERM = (unknown) OPENWINDOW
|Type OPENWINDOW unknown
|TERM = (unknown) OPENWINDOWS
|Type OPENWINDOWS unknown
|TERM = (unknown)
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 352-6511 ext 526 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
