statistics for GIS?
"""It would not be hard to imagine using much of the functionality of
S-Plus, from classification and regression trees to data visualization.
This would be a significant addition to the usefulness of GRASS."""
There is no reason to do not use Splus for the statistical analysis
of data coming from Grass. I do it a lot, I would say most of the time.
It requires writing few and simple Splus functions.
i missed the original thread, but the above comments caught my eye.
i currently use S-Plus and GRASS daily. i dump data from grass
into S-Plus, a trivial matter as Agus said. however, the return
trip is not trivial, or if it is, my abilities are less than trivial.
i use the binary-tree capabilities of S-Plus and need to reproduce
the tree structure in a language that GRASS understands, not the
S-Plus object stored and maintained in S-Plus for further tree
analyses and prediction. S-Plus will not handle data sets the size
of which i am using, so i go through the painful and tedious process
of reconstructing the final trees in r.mapcalc. an interface between
S-Plus and GRASS would presumably eliminate this step. i currently
plan to switch to arc/info since i understand that it does talk to S-Plus,
or will in the near future. i would rather stick with grass.
venables and ripley's new book on S-Plus is outstanding and includes
even more spatial statistics that are a gis dream. they
supplement mccauley's previous contributions, and are likely to
get more use and support given mccauley's overloaded work schedule.
at this point i feel S-Plus is SO valuable that it makes more sense
to switch gis's than mathematical packages.
if you read between the lines here, my programing abilities a poor,
and someone else could surely write a routine to transfer the tree
objects into GRASS. has anybody out there done this? the bigger
picture and the more pertinent question (that i probably missed in
the original message) is whether an interface is planned that would
allow use of all of the current S-Plus pearls in GRASS?
kelly
kelly@icess.ucsb.edu
"""however, the return
S-Plus and GRASS would presumably eliminate this step."""
I'm a bit confused about your needs. Could you provide an example?
What I normaly do is to use Grass to generate data files according to
GIS (grass) rules. Then I Use Splus over those files and bring the
results to grass again for display and further GIS processing. To
import/export to/from Splus I use simple functions that are based
on write and scan Splus commands. The most "sophisticated" (but still
very simple) is the function that I wrote to import binary (cell)
grass files to Splus (and the equivalent to export it).
"""i currently
or will in the near future."""
Could you detail what kind of "talk" they perform?
Agus
