Still having problems selecting monitors
I am still having problems selecting monitors in grass. As before,
starting a monitor without selecting it is no problem. However, when it
tries to select, it just hangs. Following is the output of strace from
when I tried to select the monitor.
Scott Smith
execve("/opt/grass5/bin/d.mon", ["d.mon", "select=x0"], [/* 58 vars */]) = 0
brk(0) = 0x8081f50
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=24965, ...}) = 0
mmap(NULL, 24965, PROT_READ, MAP_PRIVATE, 4, 0) = 0x40015000
close(4) = 0
open("/lib/libm.so.6", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0755, st_size=543826, ...}) = 0
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0>\0\000"..., 4096) = 4096
mmap(NULL, 118488, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4001c000
mprotect(0x40038000, 3800, PROT_NONE) = 0
mmap(0x40038000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x1b000) = 0x40038000
close(4) = 0
open("/lib/libnsl.so.1", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0755, st_size=376092, ...}) = 0
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\3009\0"..., 4096) = 4096
mmap(NULL, 89032, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x40039000
mprotect(0x4004b000, 15304, PROT_NONE) = 0
mmap(0x4004b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x11000) = 0x4004b000
mmap(0x4004d000, 7112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4004d000
close(4) = 0
open("/lib/libc.so.6", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0755, st_size=4223971, ...}) = 0
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\204"..., 4096) = 4096
mmap(NULL, 1025596, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4004f000
mprotect(0x40142000, 30268, PROT_NONE) = 0
mmap(0x40142000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xf2000) = 0x40142000
mmap(0x40146000, 13884, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40146000
close(4) = 0
mprotect(0x4004f000, 995328, PROT_READ|PROT_WRITE) = 0
mprotect(0x4004f000, 995328, PROT_READ|PROT_EXEC) = 0
munmap(0x40015000, 24965) = 0
personality(PER_LINUX) = 0
getpid() = 350
brk(0) = 0x8081f50
brk(0x8081f70) = 0x8081f70
brk(0x8082000) = 0x8082000
umask(022) = 022
ioctl(0, TCGETS, {B9600 opost isig icanon echo ...}) = 0
access("/opt/grass5/etc/bin/main/cmd/d.mon", F_OK) = 0
execve("/opt/grass5/etc/bin/main/cmd/d.mon", ["d.mon", "select=x0"], [/* 58 vars */]) = 0
brk(0) = 0x80854cc
close(4) = 0
mmap(NULL, 89032, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x4001c000
mprotect(0x4002e000, 15304, PROT_NONE) = 0
mmap(0x4002e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x11000) = 0x4002e000
mmap(0x40030000, 7112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40030000
close(4) = 0
mmap(NULL, 118488, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0) = 0x40032000
mprotect(0x4004e000, 3800, PROT_NONE) = 0
mmap(0x4004e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x1b000) = 0x4004e000
close(4) = 0
close(4) = 0
getpid() = 350
brk(0) = 0x80854cc
brk(0x80854ec) = 0x80854ec
brk(0x8086000) = 0x8086000
open("/users/smit/.grassrc5", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0666, st_size=119, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40015000
read(4, "GISDBASE: /users/smit/gis\nLOCATI"..., 4096) = 119
read(4, "", 4096) = 0
close(4) = 0
munmap(0x40015000, 4096) = 0
access("/users/smit/gis/Boston", F_OK) = 0
stat("/users/smit/gis/Boston/PERMANENT", {st_mode=S_IFDIR|0777, st_size=1024, ...}) = 0
getuid() = 18369
geteuid() = 18369
getuid() = 18369
geteuid() = 18369
umask(022) = 022
close(4) = 0
rt_sigaction(SIGINT, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigprocmask(SIG_BLOCK, [CHLD], , 8) = 0
vfork() = 351
wait4(351,
Scott,
I had a problem like this, too. It happened with both v5.0b6 and b7. I
fixed it by copying the $GRASS/etc/mon.select file from my old v4.2
installation into my new v5.0 /etc directory (overwriting the v5.0
mon.select) and all works great. I can't remember how or why I arrived at
that solution, but it did fix my problem.
BTW, I use linux 2.2.13 (redhat 6.1), and compile GRASS from source.
Perhaps your setup and problem are different.
Good luck,
Jeff P. Hollenbeck
Dept. of Forest Resources
Oregon State University
Corvallis, OR 97331
hollenbj@ucs.orst.edu
Scott Smith
brk(0) = 0x8081f50
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
getpid() = 350
brk(0) = 0x8081f50
umask(022) = 022
brk(0) = 0x80854cc
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
getpid() = 350
brk(0) = 0x80854cc
close(4) = 0
getuid() = 18369
geteuid() = 18369
getuid() = 18369
geteuid() = 18369
umask(022) = 022
close(4) = 0
vfork() = 351
wait4(351,
Scott and Jeff,
unfortunately we could not find the bug yet and fix it.
From tests we found that it is a bug only occuring on
Linux systems (no problem on SGI).
We keep it in mind and try to fix it for the next
release of GRASS 5 (late summer).
Markus Neteler
On Fri, Jul 21, 2000 at 03:21:31PM -0700, Jeff P. Hollenbeck wrote:
Scott,
Good luck,
Jeff P. Hollenbeck
Corvallis, OR 97331
> Scott Smith
> brk(0) = 0x8081f50
> close(4) = 0
> close(4) = 0
> close(4) = 0
> close(4) = 0
> getpid() = 350
> brk(0) = 0x8081f50
> umask(022) = 022
> brk(0) = 0x80854cc
> close(4) = 0
> close(4) = 0
> close(4) = 0
> close(4) = 0
> getpid() = 350
> brk(0) = 0x80854cc
> close(4) = 0
> getuid() = 18369
> geteuid() = 18369
> getuid() = 18369
> geteuid() = 18369
> umask(022) = 022
> close(4) = 0
> vfork() = 351
> wait4(351,
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
