SUMMARY: Arc/Info to GRASS conversions - comp.infosystems.gis #10629
[I thought that it would be good if this information made it into the
GRASSHopper archives, hence the post --jdm]
In article <9308271544.AA12719@vcgi.uvm.edu>, Steve Bower <steveb@VCGI.UVM.EDU> writes:
|> SUMMARY: Arc/Info -> GRASS data conversions.
|> NOTE: The original question went out on GIS-L and ESRI-L, thus so does the
|> response. Sorry for the cross-posting, they're identical.
|> ORIGINAL QUESTION:
|> We are an Arc/Info shop, but would like to distribute data in a format for
|> conversion to GRASS. All I know (from one source) is that I should
|> provide the data in DLG format with no transformation. I've read ARCDLG,
|> so I know that attributes are a pain: that is, I believe I will have to
|> convert my attribute tables to MAJOR/MINOR pairs, or generate an ACODE
|> file.
|> Does anyone have any automated programs or other custom software for this
|> conversion? Any tricks of the trade and known pitfalls would be
|> appreciated. A summary will be posted - thanks in advance.
|> Steve Bower, Vermont Center for Geographic Information, 802-656-4277.
|> #####################################################> Next response:
|> Return-Path: cg@cast.uark.edu
|> I've done some data conversion between Arc/Info and GRASS.
|> I wrote a step by step process, and hope you find it helpful.
|> TOPIC: Convert a polygon coverage from Arc/Info to GRASS
|> Use a coverage named 'school' as an example to show the procedure:
|> STEP 1. --- Get data out of Arc/Info
|> 1.1 get line data
|> Arc: ungenerate line school school.lin
|> 1.2 get label point data
|> Arc: ungenerate point school school.lab
|> 1.3 get label text (attribute) data from INFO
|> ENTER COMMAND >OUTPUT ../school.txt
|> ENTER COMMAND >SELECT SCHOOL.PAT
|> 12 RECORD(S) SELECTED
|> ENTER COMMAND >LIST PRINT (See Note2)
|> ENTER COMMAND >Q STOP
|> school.txt should look like this:
|> $RECNO AREA PERIMETER SCHOOL# SCHOOL-ID SCHOOL-NAME
|> 1 -2.46815E+09 216,729.700 1 0
|> 2 3.871248E+08 121,106.100 2 5 Springdale
|> 3 2.923594E+08 114,518.100 3 11 Fayetteville
|> 4 2.754085E+08 144,500.300 4 6 Prairie Grove (See Note1)
|> 5 83192210.000 54,980.120 5 7 Farmington
|> 6 98547120.000 53,769.720 6 4 Siloam Springs
|> 7 3.852254E+08 112,999.100 7 3 Lincoln
|> 8 2.611844E+08 101,406.700 8 1 Elkins
|> 9 1.898218E+08 112,633.000 9 8 Greenland
|> 10 2.734009E+08 101,322.400 10 9 West Fork
|> 11 1.676338E+08 66,904.990 11 2 Winslow
|> 12 54256160.000 32,175.590 12 10 West Fork
|> STEP 2. --- Bring data into GRASS
|> 2.1 create a subdirectory called 'arc' in your current mapset if necessary and
|> copy school.lin school.lab school.txt to the 'arc' directory
|> GRASS 4.1beta > v.in.arc type=polygon lines_in=school.lin points_in=school.lab
|> text_in=school.txt vector_out=sch_dist idcol=5 catcol=5 attcol=6
|> GRASS 4.1beta > v.support map=sch_dist
|> Note1: If the attribute text contains blank, (for example, Prairie Grove), the
|> second word is dropped after running 'v.in.arc'. My only suggestion
|> is to edit the dig_cats file so that the complete attributes can be
|> retained.
|> Note2: If the PAT file contains a lot of columns, you have to use the INFO
|> command - REPORT to create a report which looks like the above
|> example(school.txt). For more information about REPORT refer to
|> INFO Reference Manual.
|> Return-Path: fsbo/S=H.SHOVIC/OU=R01F11A@mhs.attmail.com
|> OK, here is our procedure. This uses GRASS 4.0 (MASSCOMP) and ARC
|> 6.1.1 (DEC). UNGEN LINES to get *.LIN file. Do not use POLY option.
|> UNGEN POINT to get *.LAB file. Then go to INFO,
|> OUTPUT *.TXT
|> SEL *.PAT of the coverage of interest
|> DISP list of variables you want in GRASS (see manual) PRINT
|> This creates and writes to the *.TXT file.
|> Then go to GRASS to import.
|> Henry SHovic
|> Return-Path: camann@pick.uga.edu
|> I have done a number of A/I to GRASS conversions. The basic technique
|> is:
|> 1) UNGENERATE the ARC coverage. Coverages that will end up as GRASS
|> vector files need only lines, e.g. UNGENERATE lines <your_coverage>.
|> Those that contain polygons and are destined to become raster layers
|> need lines and points, eg:
|> UNGENERATE lines <your_coverage> <lines_output_filename>
|> UNGENERATE points <your_coverage> <points_output_filename>
|> Next, use DISPLAY or PRINT (I think-- this is from memory) from within
|> INFO to print out the fields you need from the database.
|> 2) Move all of the ungenerated files and the database text files to
|> $LOCATION/arc-- you'll probably have to create the arc directory
|> yourself. The files MUST be in this directory. $LOCATION is defined
|> by GRASS at startup, so if you mv them from within a GRASS session,
|> they'll go to the right place.
|> 3) Use v.in.arc to suck the files into GRASS. The g.manual entry
|> explains things pretty well. This is probably where problems will
|> occur if any occur at all. This program is touchy about the format of
|> the ungenerated file.
|> 4) Run v.support on the resulting file. Be sure to use the <build>
|> option. In my experience, v.support generates tons of error messages,
|> but few of these are ever significant, so don't let them throw you.
|> 5) Run v.digit on the v.support output. At a minimum, run v.digit with
|> no digitizer (mouse mode), fill in the information regarding scale,
|> window boundaries, etc, then let v.digit draw the file. When it
|> finishes, you can either save the resulting vector layer as is or
|> modify it. If it is destined for raster-hood, you should probably
|> check and make sure that all polygons are closed-- see the v.digit
|> tutorial for additional details if you need them.
|> 6) If you want to build raster coverages, run v.to.rast on the vector
|> layer after v.digit. As I recall, v.to.rast creates a HUGE temporary
|> file, so be sure you have lots of disk space available.
|> 7) Run r.support to assign a color table, check category labels, etc.
|> Voila-- you're done!
|> Good luck-- let me know if I can be of any further assistance.
|> Michael Camann camann@dial.pick.uga.edu
|> Department of Entomology camann@athena.cs.uga.edu
|> University of Georgia (706) 542-1388
|> Athens, GA 30602 (706) 542-2276
|> Return-Path: gislist@crdokokl.cr.usgs.GOV
|> I recently sent some coverages to someone using GRASS, and he wanted them
|> in UNGEN format. That is a very simple ASCII-file format for line and
|> point coords. You can add an ASCII attribute file, as well. I haven't
|> heard back from the fellow after the last attempt (it has taken 2 or 3),
|> but that time he faxed me the GRASS manual pages, and I think we got it
|> in a form he could use. Following are some notes I made so I could keep
|> track of how this was done:
|> How to export a polygon coverage to GRASS GIS: ahrea 8/2/93
|> In order to provide geology coverages to J.D. (Mike Smolen's grad
|> student at OSU), I had to experiment a couple of times to get a
|> transferable format. The GRASS 4.0 command v.in.arc can read
|> ungenerate files. For a polygon coverage, it needs 3 files: lines,
|> label points, and attributes. The attribute file needs to contain the
|> following items: cover-id; an integer category number; optional category
|> descriptive text. To create a category number, I used frequency to add
|> the CASE# item to the coverage pat. (The help file for frequency is wrong,
|> it does NOT automatically add the CASE# item to the in_file.) I then used
|> the TABLES unload command to output the files to ascii.
|> Here is an example:
|> Enter Command: unload
|> Usage: UNLOAD <out_file> {item...item} {DELIMITED | COLUMNAR <format_file>}
|> {INIT}
|> Enter Command: unload /var/ftp/pub/gis_data/woodward.txt woodward-id case# ~
|> Enter Command: stunit columnar /var/ftp/pub/gis_data/woodward.txt.fmt init
|> Unloading data to /var/ftp/pub/gis_data/woodward.txt.
|> Unloading format to /var/ftp/pub/gis_data/woodward.txt.fmt.
|> Enter Command: q stop
|> The only drawback to this method is the columnar option doesn't insert any
|> space between columns. I'll let J.D. deal with that if it's a problems for
|> GRASS. Hopefully, this should do it.
|> I hope this helps.
|> Alan Rea, Hydrologist * ahrea@csdokokl.cr.usgs.gov (USE THIS ONE!)
|> U.S. Geological Survey * "None are more hopelessly enslaved than those
|> Oklahoma City, Oklahoma, USA * who falsely believe they are free" -- Goethe
|> Any opinions are my own, and do not represent those of my employer...
|> Return-Path: westk@BCC.ORST.EDU
|> Probably the easiest way to do it is to output the features from A/I with the
|> "ungenerate lines" command. Place the files it produces in your $LOCATION/arc
|> directory and use v.in.arc to convert them. The arc directory doesn't exist
|> by default you will have to create it. Read the man pages for v.in.arc for
|> the specifics.
|> Hope this helps!
|> ken
|> Kenneth J. West The word "set" has more meanings than any other word
|> westk@ava.bcc.orst.edu in the English language, 128 noun, 56 verb, 10 adj.
|> Since GRASS is a Raster tool, primarily, and ARC (GRID) will generate GRASS
|> output ... have you considered that route? You should retain the attributes
|> then - the flip would be in converting ARC vector data into GRIDs before
|> making the raster ... Is this an option? (Assumes also workstation ARC, rather
|> than pc, and 6.1 onwards, of course ...)
|> Peter Halls
|> University of York
|> PJH1@UK.AC.YORK - or t'other way about
|> Return-Path: malcolm@cast.uark.edu
|> Steve,
|> GRASS has an import module specifically for dealing with ARC files. It works
|> well, but there are a couple minor details. The GRASS command v.in.arc requires
|> input files in the ARC UNGENERATE format. The line and attribute files work
|> straight from UNGENERATE, but the label files have to be manually produced from
|> INFO (at least, that's how we do it). If the lines in ARC were double-precision,
|> they have to be fixed so that GRASS can read them. I use the following shell-
|> script:
|> #!/bin/sh
|> # *** arc2grass.lines ***
|> # Written by Malcolm Williamson
|> # This program will fix ARC ungenerated double-precision line files
|> # so that they are readable by GRASS v.in.arc program.
|> # File names will have to be changed.
|> awk '{ if ($1 == "END") {
|> print $0
|> else
|> if ( NF == 3 ) {
|> $2 = substr($2,3,6) "." substr($2,9,9)
|> $3 = substr($3,3,7) "." substr($3,10,8)
|> print " " $1 " " $2 " " $3
|> else {
|> $1 = substr($1,3,6) "." substr($1,9,9)
|> $2 = substr($2,3,7) "." substr($2,10,8)
|> print " " $1 " " $2
|> }' inputfile > outputfile
|> exit 0
|> I have include the GRASS manual page for v.in.arc. I recommend you look at it
|> carefully. I can answer more questions for you later, but I need to run right
|> now.
|> v.in.arc <alpha> GRASS Reference Manual <alpha> v.in.arc
[man page deleted]
|> Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
|> Center for Advanced Spatial Technologies Telephone: (501) 575-6159
|> Ozark Rm. 12 Fax: (501) 575-3846
|> University of Arkansas
|> Fayetteville, AR 72701
James Darrell McCauley Dept of Ag Engineering, Purdue Univ
internet: mccauley@ecn.purdue.edu West Lafayette, Indiana 47907-1146, USA
bitnet: mccauley%ecn@purccvm UUCP: pur-ee!mccauley
