X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Content-Lines: 64
In spite of suggestions from David Houlder and others I have not succeeded
in getting our HP XL300 to accept Postscript output from ps.map.
# entry for the HP XL300 color postscript printer
hpjet|lp2:\
:lp=/dev/ttyb:\
:sd=/var/spool/hpjet:\
:lf=/var/spool/hpjet/log:\
:mx#0:\
:sf:\
:sh:\
:br#9600:\
:ms=-parity,ixon:
We have a HP Painjet XL which and gave it connected to the serial port of
an IPC running SunOS 4.1.3 (and previously, 4.1.1). The following are a
couple of entries from out printcaps:
# HP-Paintjet XL colour plotter connected to ttya
pjetxl|pjet|pj|HP Paintjet-XL:\
:lp=/dev/ttya:\
:sd=/usr/spool/pjet:\
:lf=/usr/adm/lpd-pjet.log:\
:af=/usr/adm/lpd-pjet.act:\
:br#19200:\
:mx=#0:\
:fc#0177777:fs#003:\
:sh:sb:rw:\
:ms=ixon,evenp,-echo:
# apple laserwritter connected to ttyb
alw|ps|apple|ALW|PS|APPLE|Apple Laserwriter NT:\
:lp=/dev/ttyb:\
:sd=/usr/spool/alw:\
:lf=/usr/adm/lpd-alw.log:\
:af=/usr/adm/lpd-alw.act:\
:br#9600:\
:mx=#0:\
:ms=ixon,-echo:\
:sh:sf:sb:rw: \
:if=/usr/local/lib/psif:\
:fc#0177777:fs#003:
The dip-switches on the plotter are set up to use 19200 baud, even parity
and Xon/Xoff handshaking, the laser are set to 9600 baud and Xon/Xoff. Note
that for the postscript entry, the rw flag is used so that error messages
can be sent back. The file /usr/local/lib/psif is just a filter for converting
non-ps files into ps.
Hope these might give you a few more ideas ......
phil
Phil Watson (an ozzie in exile) | _--_|\ | CLUWRR |
phil.watson@newcastle.ac.uk | / \ | Agric & Environmental Science|
| \_.--._/ | Uni of Newcastle-Upon-Tyne |
Phone: (091) 222 7503 | v | England, NE1 |
X-Sun-Data-Type: default
X-Sun-Data-Description: default
X-Sun-Data-Name: .signature
X-Sun-Content-Lines: 4
