Without the advantage of seeing the messages you are getting, there may be one
of two problems:
1) you did not edit the lists/local file which tells the compiler which
display device you are using, or
2) you haven't a path to the X include files needed to compile those modules
in the "display section" that require them. See the comment lines in the
following file:
../src/display/devices/XDRIVER/XDRIVER/Gmakefile
