A17798%zorro?cecer?army?mil}@bnr.ca>
followup-to: info.grass.user
summary: yes, it works
organization: US Army Corps of Engineers - CERL
newsgroups: info.grass.user
originator: daemon@ux1.cso.uiuc.edu
In article <199504251910.OAA17798@zorro.cecer.army.mil> grassu-list@max.cecer.a
rmy.mil writes:
In info.grass.user you write:
have to buy one seperately apparently), so we are thinking of using using the
GNU freeware gcc C compiler.
Has anybody any advice on this - I don't want to start getting into any
I compiled grass 4.1.x under linux using gcc. The only problem that I
ran into was that you need to compile with -fwritable-strings in the
CFLAGS variable for gmake. (In certian parts of the code literal strings
are modified which is a no-no by default for gcc).
Ditto for Solarsi 2.3. Without -fwritable-strings, ps.map breaks.
Other than that, it works great. (I also use -Wall, which can
be very revealing
--Darrell
James Darrell McCauley, Ph.D. mccauley@diego.cecer.army.mil
Tel: (317) 494-1198 http://www.cecer.army.mil/~mccauley/
