surface area
Hi GRASS community,
is it possible to calculate the surface area of a 3d (not 2d!!) surface (DEM)?
Thanks in advance
                Frank
       Frank Lederer
       Sandweg 64
       60316 Frankfurt/Main
       Germany
    Lederer@em.uni-frankfurt.de
    phone: ++49-069-4960545
First, calculate the surface areas of individual cells using a slope map,
then generate a sum of the cell values, using r.stats and a spreadsheet.
Good Luck
Angus.
On Tue, 20 Jan 1998, Frank Lederer wrote:
Hi GRASS community,
Thanks in advance
                Frank
       Frank Lederer
       Sandweg 64
       Germany
r.stats -1z input=surface_area_map | awk '{ areasum+=$1 } END{ print
areasum}'
will save you from having to export to a spreadsheet.
  -Malcolm
Good Luck
Angus.
> Hi GRASS community,
> Thanks in advance
> Frank
> Frank Lederer
> Sandweg 64
> Germany
