surface from topo map?
I would appreciate hearing from anyone who has ever made an elevation surface
from a rasterized topo map.
I have tried nearly everything I can think of in GRASS, without success.
r.surf.contour has a bug, it seems, that makes it fatally slow. (Months
of cpu time for the area I would like to make a surface for.)
I have been unable to get r.surf.idw to run without core dumping.
r.surf.idw2 runs sporadically, and also core dumps frequently.
I'm running under ultrix 4.2 on DEC hardware; the data is in a utm coordinate
system.
ANY advice or suggestions would be greatly appreciated!
Neel Smith
nsmith@polar.bowdoin.edu
