surface generation
Hello Grass Users,
I want to produce a surface contour from a file having contour lines and also
points with elevation values. This way the surface generation is more accurate
since there is more information.
Is this possible?
In what format should it be?
You can convert your contour vector file to a points-file with all
vertices of the contours using v.to.sites. Then append this to your list
with point elevations (cd $LOCATION/site_lists; cat file1 >> file2) and
run s.surf.tps. That should do.
Philip Verhagen
      S t i c h t i n g R A A P
    Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
          1018 TV Amsterdam
           THE NETHERLANDS
phone/fax: (31) 20 525 5834
e-mail: motte@hacktic.nl
