SV: SV: [Geoserver-devel] SLD Validation??
Hi Rasmus,
I tried both of your styles and they both worked for me. The first one i had to put the ogc:Filter element after the MaxScaleDenominator element in the first rule however.
So I am pretty sure that the validator cannot find the the sld schema. I will need a bit more information.
How are you running geosever? Did you use the installer? It could be that I cannot reproduce the problem because I am running from by devel environment. If that is the case it might be a problem with the installer.
-Justin
p.s Dont worry, we wont leave you hanging for the holidays :slight_smile:
Rasmus Lindberg wrote:
Thanks, but it doesn't matter. I run RC7 so I think that
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="schemas/sld/StyledLayerDescriptor.xsd"
    xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
should work, but it doesn't.
I would be very happy if you can help me so that I can work over the
holiday.
/ Rasmus Lindberg
-----Ursprungligt meddelande-----
Från: Justin Deoliveira [mailto:jdeolive@anonymised.com] Skickat: den 22 december 2005 18:21
Till: Rasmus Lindberg
Kopia: geoserver-devel@lists.sourceforge.net
Ämne: Re: SV: [Geoserver-devel] SLD Validation??
Hi Rasmus,
I just found a faq entry for this one.
http://docs.codehaus.org/pages/viewpage.action?pageId=40403
Hopefully that fixes your problem.
-Justin
I can include my SLD-file, but I don't think it matter. I just tried one
more time to Config->Data->Style->New. I set StyleID to "test" and then
tried to upload the file d:\www\SLD\default_line.sld which I copied from
my
GeoServer-folder and I got the same problem. See
http://raz.dns2go.com/sld/styleEditorSubmit.htm
http://raz.dns2go.com/sld/default_line.sld
If you want to see my SLD file that I tried before it is here
http://raz.dns2go.com/sld/storaav.sld
/ Rasmus Lindberg
Från: geoserver-devel-admin@lists.sourceforge.net
[mailto:geoserver-devel-admin@lists.sourceforge.net] För Justin Deoliveira
Skickat: den 22 december 2005 17:33
Ämne: Re: [Geoserver-devel] SLD Validation??
Hi Rasmus,
Can you include the sld document. Thanks.
-Justin
Sorry for my really bad formulated question.
I start over and try to explain me a bit more.
I have installed RC7 and it seam to work. I have manged to store a
shp-file
and it works to wiew it in uDig. Now I have tried to upload the SLD-file
that I have made for this shp-file. But I get this mess
cvc-elt.1: Cannot find the declaration of element 'StyledLayerDescriptor'.
When it is validated. I have tried to copy-rename-upload one of the
SLD-files that I found in the conf\styles folder but I get the same mess.
What was done with SLD Validation now for RC7? I supposed/hoped that SLD
validation sholud be no problem but I was probobly wrong.
/ Rasmus Lindberg
This SF.net email is sponsored by: Splunk Inc. Do you grep through log
files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Quoting Justin Deoliveira <jdeolive@anonymised.com>:
Hi Rasmus,
one i
element
schema. I
devel
installer.
Also check that you have an sld xsd documents at
http://localhost:8080/geoserver/schemas/sld/ This is where geoserver
looks for them. If they're there, the only thing I could think of is
that maybe your path is kind of weird. What is the path you installed
GeoServer at? We get the local base file path, and then look in
schemas/sld for the xsd file (this is from memory, so slight chance I
could be wrong about that actual path, but I'm pretty sure it's right).
Chris
-Justin
the
> holiday.
> / Rasmus Lindberg
> Hi Rasmus,
> -Justin
tried one
then
from
> my
>>/ Rasmus Lindberg
Deoliveira
>>Hi Rasmus,
>>-Justin
>>shp-file
SLD-file
the
same mess.
that SLD
>>>/ Rasmus Lindberg
log
>>files
makes
SPLUNK!
>>>_______________________________________________
>>>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Justin Deoliveira
log files
SPLUNK!
This mail sent through IMP: https://webmail.limegroup.com/
:frowning: Not my day today
http://localhost:8080/geoserver/schemas/sld works fine. But can still not
get it to work. I have used the Windows installer
http://prdownloads.sourceforge.net/geoserver/geoserver-1.3.0-RC7.exe?downloa
d
and I have installed it in my C:/Program/Java/ folder and ther I put JDK and
JAI too. I have not tried to much otehr stuff today because I fond this
problem and have tried to solve it, but I know that I can view the shp-file
I uploaded.
/Rasmus
Från: Chris Holmes [mailto:cholmes@anonymised.com]
Skickat: den 22 december 2005 20:00
Till: Justin Deoliveira
Kopia: Rasmus Lindberg; Geoserver-devel
Ämne: Re: SV: SV: [Geoserver-devel] SLD Validation??
Hi Rasmus,
one i
element
schema. I
devel
installer.
Chris
-Justin
the
> holiday.
> / Rasmus Lindberg
> Hi Rasmus,
> -Justin
tried one
then
from
> my
>>/ Rasmus Lindberg
Deoliveira
>>Hi Rasmus,
>>-Justin
>>shp-file
SLD-file
the
same mess.
that SLD
>>>/ Rasmus Lindberg
log
>>files
makes
SPLUNK!
Justin Deoliveira
log files
SPLUNK!
Brent,
Can you try to reproduce this one (or anyone else running windows for that matter).
-Justin
d
I uploaded.
/Rasmus
Från: Chris Holmes [mailto:cholmes@anonymised.com] Skickat: den 22 december 2005 20:00
Hi Rasmus,
one i
element
schema. I
devel
installer.
Chris
-Justin
the
holiday.
/ Rasmus Lindberg
Hi Rasmus,
-Justin
tried one
then
from
my
/ Rasmus Lindberg
Deoliveira
Hi Rasmus,
-Justin
shp-file
SLD-file
the
same mess.
that SLD
/ Rasmus Lindberg
log
files
makes
SPLUNK!
Justin Deoliveira
log files
SPLUNK!
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
Justin Deoliveira
Yes I can reproduce this error... It seems to have been introduced with the new 'data dir' configuration.
Switch back to RC6 and try it. I will try to get it working today.
PS. I thought I had fixed this problem, but I guess not.
Brent Owens
TOPP
d
I uploaded.
/Rasmus
Hi Rasmus,
one i
element
schema. I
devel
installer.
Chris
-Justin
the
holiday.
/ Rasmus Lindberg
Hi Rasmus,
-Justin
tried one
then
from
my
/ Rasmus Lindberg
Deoliveira
Hi Rasmus,
-Justin
shp-file
SLD-file
the
same mess.
that SLD
/ Rasmus Lindberg
log
files
makes
SPLUNK!
Justin Deoliveira
log files
SPLUNK!
