This may not be appropriate for the group. But I am putting this
question because you all dwell a lot in the UNIX world.
Is there a UNIX program/command to determin the block size of
a media ?
Thanx
Nalneesh Gaur
a media ?
Thanx
Nalneesh Gaur
question because you all dwell a lot in the UNIX world.Is there a UNIX program/command to determin the block size of
a media ?
Nalneesh:
Since you posted to the GRASS User's List I assume you are running GRASS?
GRASS itself has a program called "m.examine.tape" which can report all
the Blocksize on a tape. This is especially useful if all the blocks are
NOT the of the same size!
Lawrence Houston - (grass@boyd.geog.mcgill.ca)
