TclTk NVIZ - was Re: [GRASS-dev] missing programmer's manual?
On Thu, Jan 1, 2009 at 6:53 PM, Michael Barton <michael.barton@asu.edu> wrote:
On Jan 1, 2009, at 10:27 AM, Markus Neteler wrote:
I guess I found it. The directory should be now populated with PDFs over
the next hour.
However, NVIZ isn't documented with doxygen, basically the GRASS libs
are.
Is NVIZ documented anywhere?
The TclTk NVIZ not too much (a few README are in the source code).
And NVIZ2 are "only" (luckily) 1500 lines, way easier to follow.
What are you looking for specifically in TclTk NVIZ?
