It is becoming a torment
I am using a Sun SparcStation20 running Solaris 2.6, under CDE. I
downloaded from linuxapps a small scientific calculator (MoCalc)
developed in TclTk. I downloaded and installed it as normal user, not
root, and it works.
So it has to be something related to tcltkgrass, right?
I am clueless now. What else can it be? Is there any Solaris user out
there that can give some advice?
thank you
stefano maffulli
Markus Neteler wrote:
Hi Stefano,
well, what platform are you using? I guess there is somewere
an error with permission. The tcltkgrass is very friendly, it
does not write anything as far as I know.Perhaps you try another tcl/tk software if it works. You need
an application using tcl/tk 8.0 (comparing to tcltkgrass).
Perhaps then you find the problem.tcltksoftware you may find there: www.linuxapps.com
