tcltkgrass (GRASS 5.0beta, SGI, Linux)
Hi - it's me again :slight_smile:
I have trouble starting tcltkgrass on our SGI - all I get is this (and
I really do not understand it...):
-------- snip ----------------------------------------------------------
Mapset <PERMANENT> in Location <ImageImport>
GRASS 5.0beta > tcltkgrass&
[1] 10285
GRASS 5.0beta > Error in startup script: can't read "0": no such
variable
    while executing
"exec wish8.0 "$0" "$@""
    (file "/exports/sgi/GRASS/grass5.0/bin/tcltkgrass" line 4)
[1] Exit 1 tcltkgrass
GRASS 5.0beta >
On my Linux Box there is another problem with tcltkgrass (I do not have
anything running like netscape, xv or what ever but do only have a 8 bit
display...):
bgerror failed to handle background error.
    Original error: cannot auto-load command "tkMessageBox"
    Error in bgerror: invalid command name "bgerror"
That occurs anytime I want to use the menuitems (the only way to quit
tcltkgrass is to use the quit / kill of the tcltkgrass window itself...
Any suggestions... :slight_smile:
  Have a nice weekend,
    Stephan
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch@uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
    http://earth.uni-muenster.de/~eicksch/
Hallo Stephan,
variable
    while executing
Looks like you have an old tcl tk version installed.
To find out:
Try to call wish8.0 alone (exit with exit).
Otherwise call wish and enter: $tk_version
It will complain about the number as an command name, but
the number should be 8.0. :slight_smile:
Get a new tcl tk Distribution then.
This also might be realated to a buggy or old tcl tk installation.
If it gives you no trouble, I would try installing 8.0.4. :slight_smile:
   Bernhard
