TcltkGRASS/Linux:1,2,3
Cao,
About the problem you noticed,
1) the A 10 flags
This flag is only relevant if you are compiling tcltkgrass on a
Apple Macintosh operating under AUX. If it is not your case, remove
it.
2) How to use the regular grass command in the superview
The superview is a replacement of all r.something command.
Don't expect that a d.rast will diosplay your raster in the
superview.
3) How to start tcltkgrass
get into the script directory and invoke tcltkgrass. There is
no other way ... as of today, I am working on a better version
of both the widget and the scripts that will fix that.
Thanks a lot for your comment and usenet stuff.
Since my usenet doesn't work well at all time could you send
me a copy of all your comment or bug report by email.
Thanks again,
Gilles Clement (author of tcltkgrass)
LAS Inc.
gc@copernic.lasinc.qc.ca
