temp files
I maybe a bit behind the time here, but I've just noticed that GRASS
creates a .tmp directory under each mapset. When I exit, the contents
of .tmp are not deleted leaving behind some very large files!
Does anyone know if this is a design fault or am I doing something wrong?
Andy.
Andy,
you can run a command called as clean_temp, under $(GISBASE)/etc to clean
up your temporary space.
Nalneesh Gaur
