I just compiled the tcltkgrass on Linux and played with it for a while.
But I am not sure what the proper procedure is to run tcltkgrass. Since there
is no documentation yet, I can only guess. Here is how I run it. Please
correct me if I am wrong.
1) inside X Window, start the shell script /script/tcltkgrass. A logo
shows up, then select a data set.
2) the tcltkgrass window show up, but I get the % wish sign in the back
(not sure whether it is correct).
3) at the %, type source tcltkgrass.tcl to invoke the menu (I think
I may have missed something, otherwise, why do I have to invoke the menu
manually, any idea?)
4) then everything works fine.
Suggestions or comments are appreciated.Changyong Cao
changyoc@daisy.siue.edu
Have you edited the tcltkgrass script so that the GISBASE and TCLTKGRASSBASE
are properly defined for your system? You should get a "GRASS-GRID>" prompt in
the text X window.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
