This topic needs a title
  This is a follow-up message to my earlier plea for help with
m.dem.extract. I've arrived at a solution, although an inelegant one,
that I want to throw out for net comments. Here's the background:
  I have a tape from the USDA Forest Service containing 21 USGS
DEMs from central Georgia, USA. I read the first three DEMs using the
m.dem.extract program, but was unable to continue beyond the third
because of a record format problem, presumably the unexpected presence
or absence of a type C record at the end of the third DEM file, as
described in the README file accompanying the latest incarnation of
m.dem.extract. I tried the temporary fix discussed in the README file,
without success.
  Here is a partial solution, presented for the fourth DEM on the
tape:
  First, run m.examine.tape to get the block sizes and record
counts for the DEMs on the tape. The report for the first four DEMs
on my tape was:
  file 1
     len: records
    4096: 1 - 295
  file 2
     len: records
    4096: 1 - 295
  file 3
     len: records
    4096: 1 - 295
  file 4
     len: records
    4096: 1 - 294
  ...etc.
  The next step is to get the fourth DEM off the tape and into a
disk file. I used dd for this, but skipped the first 3 * (295 + 1)
records before copying from the tape. I invoked dd with:
dd if=/dev/rmt8 of=/usr/gis/DEM/quad_name.dem bs=4096 skip=888 files=1
The dd output was:
  294+0 records in
  294+0 records out
  If you get a dd report that lists a number of records different
from that obtained for file 4 by m.examine.tape, then your skip
parameter is probably set wrong. In any event, you should check to
make sure that the first line of the resultant file contains the name of
the USGS quad in the first field. That way you know you got the whole
thing.
  To create a raster file, set your geographic region by running
m.dem.examine on the tape to find the UTM coords of each quad boundary,
then run g.region, then do:
  m.dem.extract input=/usr/gis/DEM/quad_name.dem \
  output=quad_name.dem blocksize=4096
  This is just like in the DEM data extraction tutorial except
that the DEM file is now on disk, instead of tape.
  Finally, run r.support. This process can be repeated for
however many DEM files you have on the tape.
  Ok, this works, but it's tedious. Furthermore, it's only useful
for extracting single quads. It won't work for multiple DEMs that need
to be extracted into a single region, say an 8 quad block. To do this,
we either need to fix the incorrect field in the DEM type A record or
we need a more bullet-proof m.dem.extract. The first option SOUNDS
easy, but it's really not. At the very least, every offending DEM file
from the tape would have to be written out with dd and then written
back after editing. I would feel safer copying out the whole tape,
editing, and then re-writing (or just running m.dem.extract on the
repaired file). This could take lots of disk space to accomplish,
however.
  Comments, please? And can anyone tell me which field in the
Type A record is the one that needs to be changed?
    Mike Camann
    camann@athena.cs.uga.edu
